RALLYPUG said:The knocking noise can be heard if you set off in 1st and then just take your foot off the pedal....it 'clunks' from the front right.Also,with the handbrake on put the car into 1st and and bring your foot off the clutch quickly without stalling the engine...do this a few times and you will hear the clunking.
The 'grating' noise from the front right is heard when you put the car on full right lock and drive clockwise,slowly in first,up a slight rise in the road....like a loading bay ramp or a low kerb.It sounds like the spring is turning in the strut.
Hope this doesn't spoil your weekends!
RALLYPUG said:I've paid the dosh...they fix the car.If they don't then i'll be on Watchdog with that nutter Campbell...
Penfold1977 said:My car has the same sort of issues, and it's an '05 182, but my knocking sound only happens when the car is just started up from cold. The front wheel feels like it's slipping, almost like you are trying to put in a screw with no thread left in the head.
rja cup said:I had the mod carried out by Abergavenny autos (renault dealer) last wknd on my 172 cup, it didnt stop the creaking/grinding noise, i kicked off and they had the car back on the ramps, they apparently then greased the antiroll bar bushes and this has fixed it (not sure how). i didnt get charged for the modification and my car is out of warranty.
rja cup said:Russ 0016, what mod will they actually be doing?! The common fault that 3 different technicians from my 3 local but different renault dealerships knew about apparently only takes an hour, I was originally charged £64 for an hours work before i kicked up a fuss and didnt get charged, it was the same at at Cardiff renault (hours labour about £82) and Swansea renault ( hours labour about £75?!
