Project started in need of advice
  Stagecoach Ticket
Got my black 1.2 clio tinted today along with a full clay wax and detailing looks good will get some pictures up once ive found cam again.
Was Curious about makes and prices of lowering springs. "30-35mm drop"
A freind of mine who is big on car modding said that if i was only droping 30-35mm that i shouldent worry to much about spending £100s of pounds on shocks and springs and that even cheap no make springs (£45) would be as good as the eibach pro ones i looked at (£135) with this small drop.
Is this true???
Also ive seen alot of people on here with an RS grille upgrade does anyone know where i can get hold of one and how much.?
Thanks alot
James
Is this true???
Your mates wrong to get a good setup you need to spend a lot to get anything good suspension wise eiback are the best springs only if you are only willing to chnage the springs. I'd never recomend anyone to use anything else.
as for the grill you could have done a search its discussed all the time.
