Thanks these have only been on about a year 8k miles so not very impressed. It's the preloaded bearings I have gone for so I will see what they are like.
I had a set show signs of wear after only 3k miles. To be fair to Pure they replaced them without issue.
They do however need to be pressed in/out once the circlip is removed.
Hi Guys,
Just thought I would give some advice:
To replace the bearings, remove the circlip and press the bearing out but make sure the tool you use is a tight fit with the outside of the bearing as you may leave the outer sleeve in place otherwise (the bearings have an inner and outer part)
Place some Loctite bearing fit on the outside of the new bearing (we use this to keep water out and stop the bearing seizing into the top mount, and it also lubricates the outside to make pressing easier and stop it galling)
Press the new bearing in with a tool or socket that fits on the outside of the bearing (don't press on the ball!!) until it stops then fit the new circlip. Job done.
The bearings we use as standard will corrode over time, like any unprotected ball joint, as they aren't stainless. all stainless bearings are very expensive at about £40-50 each which is why we don't use them as standard. Our pre-loaded bearings do have a stainless sleeve and chrome plated ball which will last longer in terms of corrosion resistance. The bearings are PTFE lined so shouldn't be lubricated as the lubricant can deteriorate the PTFE liner (apparently!)
On our website it shows the bearings as serviceable items meaning they are not a fit and forget part.
As with all of our parts they are designed for motorsport use.
Any plans to offer full stainless bearings as an upgrade in the future?
May be worth the initial outlay if the standard ones are having to be replaced frequently for those of us that are using them on our daily drivers.
The bearing manufacturer doesn't recommend any lubricant at all as it supposedly degrades the PTFE liner. I would have thought any petroleum based lubricant would degrade it but maybe some type of grease made for plastics might be OK.
We don't have any plans for a full stainless bearing as we sell so few replacement bearings, but we can get pretty much whatever you want if you do want to upgrade. I think NMB do an all stainless bearing but they certainly won't be cheap!
As said it will just kill them quicker, they won't be designed for any form of lubrication, just noticed these have been allowed in the regs at last for our class in sprints these will be on my shopping very soon once confirmed along with strut brace.
