Quattro S1 replica
1986 AUDI QUATTRO S1 REPLICA
Engine: Audi 2.2L five-cylinder 20-valve; Wiseco forged pistons; steel connecting rods; OEM crankshaft; Force Motorsport race-prepped/ported cylinder head; custom camshafts; oversized valves; custom Garrett-based T3/T4 turbocharger; Audi OEM external wastegate; custom air-to-air intercooler; 3-inch exhaust system; Force Motorsport alloy intake manifold; Mitsubishi 4G63 throttle body; Force Motorsport custom fabricated fuel rail; high-flow Sard 800cc fuel injectors; 2x Bosch 044 fuel pumps; alloy radiator; electric water pump; oil cooler; MoTeC M600 ECU
Driveline: Subaru V9 WRX STI 6-speed transmission casing, Pfitzner Performance Gearbox (PPG) straight-cut dog gears; Exedy twin-plate clutch; Cusco limited slip differentials front/rear
Chassis: Subaru V9 WRX STI shortened/narrowed floor pan; Force Motorsport custom fabricated front subframe; Subaru V9 WRX STI rear subframe; Audi body shortened 320mm (12.6″)
Suspension/Brakes: Subaru V9 WRX STI front/rear strut towers/tops; MCA Suspension custom-built coil-over shocks with external reservoirs; Alcon vented rotors; Alcon callipers; hydraulic e-brake; proportioning valve
Wheels/Tires: 15×7″ Compomotive Motorsport wheels; MRF ZG2 205/65R15 rally tires (gravel); 18×10″ Compomotive Motorsport wheels (tarmac)
Body: Audi Sport Quattro S1 fiberglass replica body panels, Lexan door, three-quarter and rear hatch windows; Audi Sport-style livery
Cabin: Multi-point roll cage; Sparco Evo seats; Willans harness seat belts; Sparco suede dished steering wheel; Auto Meter Ultra-Lite tachometer; Auto Meter Ultra-Lite 30psi boost meter; Auto Meter Ultra-Lite water temp meter; custom dashboard
Actually, imagine that was a fairly cost effective way of doing things! Bear in mind the Subaru base car would have been a few grand...
Looks awesome.
