Queries on running Gripper Diff
106lad
  RB 182 / E36 M3 GT2
Hi All
Few queries. I've just taken the gearbox out and get a Gripper fitted to my RB182.
While i was at the Gearbox I fitted a TTL flywheel, powerflex black bushes to wishbones, steering rack and antiroll bar.
Everything fitted back on and I've noticed a couple of things.
1. After fitting all back. Took it for a quick test and the power steering pump locked solid and the belt started slipping on the pulley. I didn't remove the rack, I left all in place and cable tied up to the manifold so no pas pipes touched. Could this be coincidental? After cooling it started working again? The steering does seem heavier?
2. When turning there's a dry rubbery rubbing noise from passenger side. I fitted the lobro shorter shaft. MT90 gearbox oil. Maybe it's the wishbone bushes?
Sorry if this has been covered. I've searched the forum and can't see anything like this.
Mark
Brigsy
  T.Turbo
Pas pump failure will be a coincidence.
Did you grease the powerflex bushes up when fitting?
106lad
  RB 182 / E36 M3 GT2
Yep. Greased them up when fitting. Jacked the front end up there can't see anything that would be fouling or rubbing when the wheels spinning. It could only be the bushes?
Brigsy
  T.Turbo
Just reread post again. The gripper diffs clunk like fcuk when turning on the street when the gear oil is cold especially at full lock or tighter bends.
Gets slightly better when warmed up a bit, you sure its not that?
106lad
  RB 182 / E36 M3 GT2
I havent moved the car since the PAS pump shat itself. I have a new one on order. But it was a rubbery noise rather than metallic clunking.
106lad
  RB 182 / E36 M3 GT2
So after completing a track day today ive come to the conclusion that it's the diff itself that's making the noises.
Its an awful creaking noise that dissappear when the car is on track under load. So must be the plates of the diff when not under load maneuvering.
Pic to make it interesting
Ph1 Tom
Plated diffs are noisy.
If you wanted to make it quieter (best check it won't cause any issues with other components) then in BMW M cars there is a friction modifier in the OEM oil added which helps to quieten the the diff. You could potentially add some to your gearbox.
However if you do this then the diff isn't as effective. Noisy diff = working diff
  Clio RS 200
I have got a Gripper in my 200. It sound like it is broken when moving at slow speeds. People often look at the car due to the terrible knocking noises it makes on full lock.
106lad
  RB 182 / E36 M3 GT2
I think at this stage that if a creaky knocky diff is working and nothing to worry about then it's fine.
Like I say. It seemed to work well on track. So that works for me.
