Jesus marc, that Trophy must owe you a fortune!
On the Invoices I have for work carried out I have a grand total of £3224.63
On parts I have bought I have spent £3739.21. This does not include any parts bought via cliosport, clio trophy or eBay.
This does not include the buying of the car, tax, insurance or petrol
Must be a keeper then!
You can loosen it to set the timing without changing it. But after loosening, you need to remove the dephaser to clean the oil away so you can retighten the bolt.
But AFAIK Renault don't even loosen the cam pulleys for a simple belt change. Their pdf says just undo the crank pulley unless you need to remove one of the cam pulleys to do something else e.g. dephaser.
Just get it checked if you are worried, it is probably fine if Renault did it.
If it goes like F just leave it or check with the horse shoe at TDC with the crank pin in.
jesus this thread has got me thinking about my timing because the 5k kick is pants and i dont have that "urgent" feeling
i had my belts done 9 month ago at kenny browns in hillington glasgow and he is ment to be good
maybe im wrong but for £70 to get it checked i will feel better
Don't forget you MUST use a specialist , as no decent mechanic can be trusted or has to necessary level of skill to set the timing on a Clio ! Haha
The age of the engine has nothing to do with the performance though, if the engines been serviced as when required it should still make decent figures - it seems to be common that the engines improve with mileage.
