Quick 172 ABS sensor question
  1987 Corvette C4 4+3
My 172 ph2 was missing the front n/s abs sensor. I brought a replacement but the plug end is the same as the plug on the loom of the car. I.e it has a male connector with two pins and so does the plug on the loom, so i cannot connect them together. Is there supposed to be a female socket in between that both plugs, plug into or do I have the wrong sensor?
  Sprint 172
Wrong connector. There are two types depending on whether you have stability control or not.
