quick few questions
Nafoff
now i know which order i am polishing / waxing in
just forgot a few little bits
i am using SRP then EGP
now is it....you apply the SRP then leave it
or
apply the EGP then leave it.....?
i know its better to apply more than 1 coat of one of those polishes too, but can't remember which.....
cheers
  "Navy" N17 TWO
Dont put the EGP on in the sun - will be a fam ducker to get off! plus you'll probably swirl the paint doing-so
Nafoff
well chaps....i have applied the SRP and taken that off, was no problem at all, i think its cooled slightly since this morning,
i have now applied 1 coat of EGP and taken it off, and then the 2nd coat has been applied, and sure enough just as i finished applying it the heavens have opened
will i be alright afterwards to just go and wipe it off again?
  106 GTi
The second layer has probaly not done much apart from ensuring even coverage - AG say to leave it 12 -24 hours between layers to allow it to set up and bond.
I would rewash the car and then try and remove it.
  106 GTi
Worth a shot as it gives a clear wet glossy work, how much difference you will see on Silver I am not sure. Just washed the 306 and polished one panel, it did not look any different so stopped left the rest!
