Quick Ph1 172 Exhaust Question regarding length
I'm looking to buy a new backbox for my Ph1 172 - am I right in thinking that only the length for the centre section differs between models with or without a post-cat lambda sensor, and therefore the backboxes are identical between all Ph1 and Ph2 172s?
You are correct about the mid section (post cat sensor or not) so would assume correct about rear section, I actually run a complete phase 2 system on my phase 1.
Depends on which cat iirc, if you have a twin sensor cat it's about 2" longer than the single sensor cat.
But yes, it's only the centre that changes Due to the cat length
