Quick release amp rack
Car  Ph1
Had the ICE install for a number of years but want to step up my quarter mile visits this year so would like to make it as quick and easy as possible to take the amp rack part out.
The way it was all plumbed in was by having two power cables running from the battery, positive and negative, to the amps.
I was going to simple use a couple of block terminels but after speaking to a mate he advised me to use a fused connector.
My question is:
Do i just need one fused connector on the positive? and use a simple block terminel on the negative feed ? or is it best to use a fuse connector on both of the power the cables?
Mate thinks i only need one on the positive, my friendly parts place said to use one on the negative feed too
Who is correct ?
you only need one on the positive. If you short the negative out on the chassis, it wont matter. If you short the positive on the chassis it will.
You don't need two.
