R5 turbo brakes same as clio 03
hiya guys,
I heard somewhere that the renault clio 1.4 16v 2003 models brakes are exactly the same as the R5 turbos brakes just with ABS...is this true? and if it is does that mean I can use brake upgrades meant for the renault 5 as Ive luve to fit a big brake conversion to look sweet but K-tec and the like only cater for the 172 at the minute!
discuss!
David
calipers might be the same but how it fits to the strut (i.e. the caliper carrier) will probably be different but i guess the only way to find out is to ask renault or whoever you are looking to buy the kit from
  320d M Sport
i was wondering the same thing as you can get Big brake kits for the 5 Turbo but only the KTec one (over £1000!!!) for the 172?
huge brembos mmmm yummy
Rear brakes on a 5 turbo are the same as those on the 16v 1.8 (Valver), but without the abs. They fit straight on.
  Lionel Richie
The Dynamique has the same calipers and therefore pads as the R5 GTT but it uses the same discs as a 1.8 16V Clio (valver!!)
Im using Brembo Max grooved discs (for a 1.8 16Valver) and Pagid Fast Road pads (for a R5 GTT) on my Dynamique
