Radio Code not working :/
Worked!!
Sam told me to do this :
"Hi Tom.
You have to press this button after you have entered your code:
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " ¬ " On The Stalk Control To Enter
If the correct Clio radiocode number is now shown
Press And Hold " ¬ " Until A Beep Is Heard.
Many thanks, Sam!"
Sorry to bump - but I get the beep but the code doesn't go away and the radio still wont work...
Am I being a silly wasp?
(code matches up with one in book AND one from above link)
Yes...
Tried multiple times, turned it on and off etc but still no luck.
Ill give it another try when I leave the office just incase I was being a complete spacktard.
It's all explained in Bonxy's post above. It's done using the stalk - make sure you're holding the button down when the code is entered for a few seconds until it comes on.
We sometimes get people who have problems when using the stalk, try the numbers on the front after you have unplugged & left for about 10 mins - you may have a radio with a cloned chip inside it which is why the codes are not working, as the sticker on the side of the radio doesn't relate to the chip inside it anymore!
