Random blocked off pipe in 172 cup engine bay, accostic valve ?
  2050cc Corsa
All new to the world of clios and french things, so bear with me
got a pipe than hangs down by the battery in the bay, has a small valve then another length of pipe on it, followed it back all the way to the inlet, where it comes off just before the tb
first of all, what is it ?, what does it do
any reason it can just be blanked off at the inlet
where should it run if connected
cheers
jr
the hose infront of the t/b (as you face the car) is for the acoustic valve
have a look underneath the n/s headlamp - the acoustic valve should be bolted to the airhorn bracket (might not be able to see it from above)
it may have been removed - it's just a plastic tube with a butterfly valve in it (operated by inlet vacuum) - reduces induction roar
no reason you couldn't cut it off closer the t/b, but it obv. needs blanking off
  2050cc Corsa
brilliant, just annoys me that i didnt know what it was, and why someone decide to leave about a meter of hose still in the bay :D
  421 Cammed 172
I left mine off for when i sell. The previous owner probably did the same then couldn't be bothered - lol
