To re-thread the wire, you'll need to pull down the cars headlining (the grey carpety stuff above your head) then follow the wire, probably a bit of a pain to do, but it's not somethnig you'll need to do again.
Erm, I really don't know. I started taking off the roof lining but I've bent the corner a bit. It's a bit of a pain in the backside to do.
I had to replace the aerial to see if it was just that, but it still didn't work, so then I wired up the aerial with the new leads (without threading it) and it worked.
