Rear allignment
Keith185
Can any improvements be done in the rear allignment on a Clio?
Front is setup at -1.5 deg camber.
with rear at -1.3deg camber (no shims) with approx 10 min toe in.
Or can anyone recomend a good setup that would be decent for both road/track keeping in mind that front camber will be no more than -2deg if I can get the extra 0.5deg on the camber.
I have -1deg camber and 0 toe with shims, car is pretty reactive with the rear the helps in the corner.
I'd have 0~2 mm each side...it could be too much of a handful in the wet with more, especially if you leave too much camber.
0.5mm washers under the lower rear hub bolts will give you about another 30mins of camber (half degree) but leave the toe as is.
we run aound 3 deg camber and a little toe out
No need for fancy shims imo. ours hasnt altered or caused any trouble
