Rear Bench Removal (Quick Question)
Car  LY 220 Trophy+IB PH1
Hey everybody, I'm in the process of moving house and I want to remove the rear seats before the stuff I carry destroys the back of the seats, when I've came to take the bolt on either side off they turn then get really tight and I'm unable to get them out
Are there any more bolts to remove other that the one on the left and right under the plastic ? Really confused as it turns great then slowly grinds to a halt as if I'm tightening it back up :S
Under the plastic is the isofix bar. IIRC thats 2 bolts, these bolts stick out the bottom of the car and so will be very rusty and hard to remove. Once there out there is one (torx) bolt, then you slide the seats backwards, you'll see what I mean when you get the isofix bar out.
Get under the car and get some WD40 on the threads of the 3 bolts you need to remove.
Cheers, Ian ! ill lube em up and consider digging the power bar out. I was worried because I've been wrong about these things before and ended up sheering something I shouldn't have xD
Mine was fine, just make sure you got exactly the right size torx driver other wise you'll round it off and be some what buggered :\
