rear break discs
Car  Golf GT TDI, IS220d
Right, i need new discs on the back of my 182.
Reno charge about £180 iirc. I need the bearings and the abs rings but the only place to get the abs rings is on the reno discs i've been told, and i carnt use the old ones - as you may have already found out, i dont know much about the rear discs.
Any help or advice give will be much apriciated, Cheers in advance :)
Is there a particular reason you can't use the original ABS ring?
BTW. Originals are £181 at Yozza and £175 at K-tec minus any discount.
Im not sure mate - this is just what ive been told. as i said i don't know much about the rear discs, especially the abs ring and if it can be re-used.
Cheers for the info chris
Typical stealers trying to rip its customers off.
May be it's their policy not to fit old rings but they should be fine.
I've had the rear discs done on two on my previous cars and used the old rings on both occasions
ok thats great cheers mate, should save me over £100 as i can just get aftermarket discs and get bearings pressed
I got new disc and pads from yozzasport for £175, the come with the bearing pressed in and the ABS rings.
Also how have you got a cup packed, cup packed 182?
what do you mean? 182FF with cup suspension and spoiler packs
I paid under £100 for rear disc and bearing, just got them pressed myself.
A garage will do it for around £10
yeah cheers i'll look into that, it will be alot cheeper if i dont need the abs rings anyway
