Rear disk help
  182 FF
Hi folks
Trying to change the rear discs on my 182. 1 Disk came off no problem the other disc seems to be stuck. It wobbles and rotates but wont come off the pin any thoughts? Alsois castrol LM grease ok for regreasing the pin etc?
haha just had to double check that! ok still wont budge it moves about 2mm as if its abt to come off then stops. More hitting?
Think I might have to wait for back up. The nearside one practically took itself off compared to this!
I'm having the same problem!
I undone the caliper nuts, so thats off. I've undone the big nut that holds the disc on.
Been hitting it with a hammer for the past five minutes, still won't come off! It wobbles about a bit, but won't come off.
hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn hit turn
