Blackgold 182
Hi guys,
Right...I replaced my rear brake discs a few months ago, I had a lot of trouble getting the nearside disc off (had to use a substantial hammer as it was missing the spacer ring). Now when I put the new disc on I also had to force it on! I've now got a noisy bearing so Im assuming I damaged the bearing when I forced it on the hub?!
I'm also assuming that the hub must have been warped slightly. Question is do I need a new hub or will I be able to maybe rub/file it down a bit so the new discs slip on as they are supposed to?!
