ripp
								182 FFAT
				I've met a guy today and his 172 is a lot lower in the back, the front is the same as mine as you can see in the pics. he says his car is on stock suspension and mine is also, so how come mine is so high??
I've measured mine in front directly under the front splitter and it is 14 cm off the ground, and in the rear it is 29 cm (give or take 5mm), measured below the bumper in the center between the tailpipes.
Can someone take a minute and measure the height of a stock 182 (cup pack) as I did?
cheers!
P.S: I'm on standard wheels and tyres, he is on 15" wheels with 195/50 tyres, but that still doesn't explain the difference. chances that my rear springs could be different from stock are minimum since I've spotted the red stripe on one of them, and this is how the cup pack ones are marked as far as I know
front:
rear:
cheers!
front:
rear:
