Rear seatbelt pre-tensioner
Car  2002 Clio 1.6 16v
The rear left seatbelt is ripped, so looking to replace it, however when i took the plastic panel off, I've noticed that it has a pre-tensioner built into it, is it possible to fit a none pre-tensioned one or does it not fit in the hole? have also been told that if I disconnet the pre tension one the airbag light will stay on is there anyway round this as I'm not bothered if it doesn't have the pretensioner on it, as pre-tensioned seatbelts seem to cost a small fortune!
Finally is it possible to take the pretension unit off and fit it onto a unit that doesn't have it on?
You can fit a standard belt - you will need to bridge the loom connector with a 3ohm resistor - this will fool the sytsem into thinking a pretensioner is fitted enabling your airbag / pretensioners to still work in the event of an accident. The airbag light will go off as well
Great stuff just what I wanted to hear, cheers for that Matt!
Does it have to be 3ohm just I've found a pack of 10 3.3 ohm on ebay for 40p
