recaro trend line seat removal
koksracing
  clio 172
Hi All, i want to remove the recaro trendiness in my 182 trophy to install a new carpet. I know on my old 182 ff that there was wiring to the seat for the airbag but pretty sure on the 182 trophy's there is no wiring and i certainlly couldn't see any looking under the seat.
If there anything more i need to disconnect or check and is it as simple as removing the 4 13mm bolts which hold the seat in.
Pete
Gus
  182Turbo,DCi90
The only thing you need to disconnect is the seatbelt pretensioner. follow the cable from the seatbelt clip near the hand brake. there is a grey connector and you slide the yellow bit away from the grey connector.
Gus
  182Turbo,DCi90
Ex-User (72296)
  Clio 172
Took me a while to work out how to unplug the above.. put a precision screwdriver or similar flat under/up the yellow bit so it pulls up.
koksracing
  clio 172
Thanks all - is it located underneath the seat? As that's where I can see the grey and yellow clip.
