Received my ph1 fuel sender wondering what this is?
Car  clio 182
received my ph1 fuel sender yesterday morning but only had chance to look at it today I took it apart to see what's what took the pump out, obviously I'm upgrading that, what's this on the return line? Pictured below?
get a photo from the other side? is it a late phase 1 its out of ads it may be the regulator... u needed a early Phase 1 one
Here's some other pics
thought it was definitely right because its got 2 connectors on top of the sender thought one would be for flow and would be return
Ones a vent for the tank ones a feed, that's defo a fuel regulator it's a late ph1172 mate, your fuel garage won't read correct with this fitted either.
I can vouch for the fuel gauge bit not working it will catch you out.
Andy is there a fix for this or is it a case of getting a new fuel sender unit?
Dude, I need a new sender as my fuel level fluctuates, im in no rush to sort it but if you struggle to sell it on ill have it. Assuming its ph2.
Edit: just read and its ph1 late. :rolleyes:
Might be the same as a ph2 if its different from a early ph1 sure someone will confirm this if not ill be selling mine out of my 182 :)
