Recommended Length Itb's
iirc there's a few people on here with the AT direct to head bodies fitted, does anyone know the optimum length for the F4r engine within the constraints of the engine bay?
Horn choices are 40 or 60mm
Extension lengths are 70, 100 or 130mm
Chris
you want to be carfull here, length is critical to mid range torque on this engine (we have done ALOT of testing)
you can run shorter than the current Jenvey kit, but will loose mid range torque, but it wont effect the top end numbers.
you really need to pop it on a dyno and see what lengths work with the setup you have to get the best result.
Andy
Cheers Daz, i just need to confirm a few things, then i can get them ordered :D
I'm surprised no one else joined in when they saw the length comment :eek:
Chris
let me know if you do any back to back comparisons, cos i've always been torn if to stick with the 90mm trumpets or go for 120mm ones
