Remove center section - much louder?
My center section (after the cat) has started to rattle on overrun at 3K and 4K. Very annoying and sounds terrible. If i had this replaced with a straight through pipe would it be much louder? Can you buy bolt in replacement, or will i be looking at a weld in/sleeve option?
Thanks.
It'll just me the normal 4k rattle if its the standard exhaust. New exhaust time, yes it'll be louder by a good way.
It will be a little bit louder.
The other thing is that it might affect performance as well(but I don't know for sure so I'm not putting my hand on fire about this)
As for a direct replacement you can do your job with this part:
873313 Centre pipe (alternative to 873303).
(Replace OEM centre exhaust).
Here is the site: http://www.supersprint.it/homeuk.htm
Mine wasn't that much louder at all, just sounded deeper. I had the 4k rattle on mine & after getting fobbed off from Renault 3 times I took it to a nearby Alba tyres. They took out my middle box & welded a straight pipe in for about £60 or less.
The guy at the garage said that box is so small it probably doesn't do anything anyway. Maybe there just to change the exhaust note.
