Removing a 182 exhaust that' been 'sleeved'
Car  997, e208, I.D. Buzz
Afternoon all,
Tried removing my 182's cat today, it's been sleeve modded and I cant get the frigging thing out. I've tried a hammer (repeatedly), WD40, GT85, more hammering, prying a gap in the centre section where it resides to 'loosen' it...
Do I really need heat to get this off? I'm at the point I might just buy another fking exhaust that go through this every time i need to remove it for whatever reason.
not really easy to twist as im doing it on stands. ive managed to put a hole in the cat from hammering it.
if i drop the rear beam and remove the exhaust - is there a way i can remove it easier (tools?) ...
Going to drop the rear beam tomorrow and remove the full thing & see what the engijeers at work can come up with...
they weld so hopefully heat and some form of vice will save the day
Yay! they removed it with a bit of brute force! Just need to get the new cat sleeved.
whats the easiest way to fit it back on? Bear in mind im doing it on stands with the rear beam dropped & backboc /centre still joined.
Cat on, backbox and centre pipe over rear beam and rubber hammer midsection onto sleeved cat?
With mid/back already joined? Can imagine it'll be difficult either way to get it back into the flange under there...
Yes but I removed the centre hanger and loosens off the rear hangers aswell then once the cat was on and fitted then re attached the centre mount, and adjusted the rears
