Removing air-can....worth it?
Chris205
Car  Many Things
Being weighing this one up for a while now. I never use my air con and from what I hear its just dead weight being carried around.
To the people who have removed it has it made much of a difference in performance and power output?
It doesn't give you any more bhp but I think the torque increases. Because the engine has less mass to rotate then if you remove the ac the it's like having a lightened flywheel, so the engine will go up the rev range quicker.
Ah ok, I was speaking with someone who said the less auxillaries on the engine the more power they tend to make....probably meant power steering etc as well
It does free up a few hp, the same as removing the power steering. Any auxiliaries on the engine will sap power.
But regardless, the aircon weighs a lot so it's worth doing either way.
mine is going soon only because I feel its in the way of my bodies but £400 fitted for saving 16kg oofftt!
