Removing Center Console Display
Car  ClioII 1.2L 2003
Hi guys.....I know there are tons of info on removing the dash and changing bulbs of the LCD but my college in work consists that I don't have to remove the whole top of the dash and just remove the half circle shape covering the display and then unscrew the 2 bolts behind them and way you go........he says " he has done it this way "
It's an MK2 PH1
Could this be possibly true!!!!??????
thanks for replies........I've done a bit of searching and found this pdf file named "Sam naprawiam Renault Clio II" and found this: could it be a certain model or what?
i have a ph 1 and cant see of any way you could get it off seperate, it is a different which could explain the picture showing it as a seperate piece
I think from looking at that pic and at my own that the top part of the dash would have to come off before you could access the screws...
