removing window tint residue
Car  RB 182 FF
Hi,
The rear side windows on my 182 have had vinyl tint on them which cracked and has now been removed. however there is some major residue left behind. normally wd40 works fine for removing sticker residue but this stuff is stubborn!
Any tips on the best methods and products?
Should i heat it up?
Thanks for your help.
I always smear a petrol soaked rag over it to soften it, then scrape with a Stanley/razor blade.
I've done 3 in the last month and it is without doubt the worst job in the world. Hate it. f**king stuff.
I had to use petrol and a blade to clean mine off , didn't smell for ages either , failing that glue or adhesive remover that sign writers use might work
PITA. I truly horrible job!
I once bought a mini cooper tailgate to replace a damaged one on a car I was doing up to sell. Only when I got it home did I notice the inside of the screen was tacky. Film removed prior to sale but residue remained :(
I bought Sticky Stuff remover from Halfords (yellow can) and then used a combination of blade or Brillo pad. Neither scratched the glass btw.
Feel for you Daniel, having to do 3!
I've had to do this before. It's a royal ball ache, as already mentioned petrol is probably the best bet.
Did it on a mates Golf and all I did was sit in the car and wack all the heaters on full and used a razor blade to scrape it all off. It worked a treat but it gets really hot. :)
I remember watching one of the cop programmes, they pulled someone about tinted windows & advised using Nail Polish Remover, to get the stickiness off?
Handy tip... If removing tints, it's much easier to get the glue to come away with the tint.
So, but a cheap wallpaper stripper (about £20) and heat the tint film with that, then peel slowly and you can remove the film and glue in one go.
I did this with my 182 the day after I bought it. The midnight tints were far too council.
Thanks for all the responses - I will give some of these a go and let you know the results.
With all of these substances - my neighbours might think I have a problem.....
Bumping this incase anyone wanted to know the results. Contact cleaner and solvent cleaner work. Paint thinner worked with very little elbow grease but definitely wear a breather. I didn't have one to hand and only lasted a few minutes before getting dizzy. The best advice is don't rip them off in the first place.....
