Removing wrong words from predictive text dictionary - tip for Nokias.
Car  ex Clio 172 owner :(
I'm sick of typing things like 'is' only to find it's brings up 'ip' as default just because I've used it once. Or words like 'and' become 'amd' because I used that once.
Found an easy way to go back to the default word if this would be useful for other people too.
-Open a blank text message and skip down to the message field.
-Type the word that appears incorrectly.
-Press the “+” key (”*”) until the correct word appears.
-Press the “Space” key (”_”/”0″) and repeat.
Should work for you.
Useful tip I thought I'd share.
so you mean type the word, change it to the correct one using * then space and do it all again?
Tried and it didn't work for me. Mine's proper messed up comes up with mk for ok or inx for how etc even though i've never used them.
Only real fix i found was doing a phone reset but cba doing it again.
just typing the smame word a few times lets it see you use that most times and puts it front of the list....or be a hom like my self and aget a full qwerty e71 :P
^^ that never seems to work in my experience.
I've typed words out over ten times and it'll still give me ip instead of is.
My method works for me anyway.
Couple of ways to try people.
