Renault clio Engine Fuse box
  Renault Clio 02
took the yellow fuse out under the bonnet not thinking about where to put it back after -_- has anyone got a picture of the fuses. ohh and id like to know what the block fuses are for.. i have a starting problem :( when i turn the key in the ignition the tach does some wierd stuff, i also noticed the middle interrior light doesnt work but the other two does? im hoping they're linked. Anyone know the answer to my problem,
  PH2 172
Yellow relay is as close as you can get to the green 30 amp fuse.If you cannot sort it,speak or go see Mick at Diamond Motors.
  Renault Clio 02
This is the fuse i took
All i know is that it goes into one of the two back slots
  PH2 172
Sorry,I saw yellow and assumed you where talking about relays.If you mean the small orangish 5 amp fuse,seated in the car it is on the left of the rear row,the centre position is not used.
  PH2 172
OH you ARE talking about relays,please refer to my former answer.
  Renault Clio 02
Thanks alot lol, do you know what those two pictures of fuses are for? need to sort this starting problem out :(
  PH2 172
Sorry my bad. is it in the right place now? and would this be the problem to my starting issue?
Yellow relay is in correct place,starting problem is probably corrosion in wiring.As I said speak to Mick before buying anything,0115 9721501
