Renault touch up pens.
Car  RB 182
After having some pikey key the RB recently I've ordered a touch up own from Renault.
Does anyone rate them??
Are there and hints and tips around using them over the standard instructions?
And is there anything that can be done to blend it in to the paint work after the instruction process has been followed.?
Yea all pens are s**t unless your good with some wet and dry and a rotary..
Yeah i have it for stone chipping... but then again with Metallic (Gris Iceberg) there's no way for blending it.
Just touching up.
1 pen is Basecoat Paint
1 pen is Laquer on Xylene base
What part of your car has been keyed?
You might need a filler first... Basecoat (High Pigmented Paint) is only so, so thin needs 2K Laquer for build.
Keyed front to back on the passenger side, some deeper than most..
Can see it looking a right arse to be honest and might well pop in and see a painter I know if it would be better for him to blow it in..
No way you can just touch that up with a 'thin' touch up pen!
Go see that painter for a quote... #doit
