Renault wiring diagrams
Car  Clio 182 cup
Hi, it's a long shot but hope someone can help. The wife's 2010 Laguna coupe has an abs fault. I'm looking for a wiring diagram as the fault is sensor open circuit. But sensor replaced and the fault won't clear and remains the same. Been a paid member on here for many years and hope someone out there can help out. I need to know the pins from the ABS ECU to the front RH abs sensor.
Thanks in advance. Sensor is 2.8K ohms one way and open the other. A diode test works across the sensor.
