Replcement Key for Mk2 Clio RS
  2003 Clio Sport
Hi, I've recently bought a second hand Clio Sport Mk 2, which only came with one key. I'm looking into how I can get a second key without spending a fortune (if possible!)
I've read this guide: http://www.cliosport.net/forum/showthread.php?585981-How-to-sync-your-central-locking-with-your-key-(new-key)&highlight=key
which looks straight forward - but the question is - will this work with a key from another car or with a blank? (ie http://www.ebay.com.au/itm/390382431238?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649)
Or is it the immobiliser that is the problem - hence it needs to come direct from Renault? I'm assuming this part needs to be programmed at some point - the cutting can be done by any locksmith.
Any clarification would be gladly received.
You need to buy a blank key and get renault to reprogram it ion the computer there no DIY option its £170ish for the fob and program if you neeed the blade/key its about another £15.
