restore a ruined valver
Car  Chav Rocket
Starting again as im w**k at doing projects or project threads for that matter! its a bit out of chronological order though as im just going by as i see photos and remember doing things lol
Bought K*** RLH end of 2008 with plans to give it a quick service and get it on the road,
Here's how she looked
on picking it up i realised that the heater blower wasnt working and alot of the dash bulbs had blown.
next day whipped the scuttle panel off and found that the plug to the blower had melted so a quick call to joshydee and a plug was with me next day, soldered that on and jobs a good un.
scuttle panel off
dodgy placement of the shield - lazy barstard however done that!
well dirty!
at the same time i replaced all the interior bulbs that i could - i need to buy some more bulbs as the ones on the oil guages are blown. also fixed the heater selector switch not working as however put it back on put it on incorrectly (the selector is mechanical)
got the car in the garage and started looking at doing the cambelt decided forget doing it in car and to crane it out, do the deed and drop it back in.
this got me to thinking that i should get new cams and lifters while the engine was out - then i decided to just get a F7R instead of the cams as better gains were to be had. fortunately for me there was a F7R (williams) block available 20 minutes from me (midge) so the day i decided to get one i managed to have one in my garage the same evening!
the next day i decided to get the cams anyway
at the same time ordered new lifters.
also went and met gaz (cliolord) for a hilpower induction setup and a williams manifold.
stripped the the head off and it was in really good condition already, dad took it to work and had it cleaned then when it got back i lapped all the valves in (a boring boring BORING job) and it was built back up using the new lifters and Catcam 225s.
at the same time i refreshed all the seals including the injector seals. had a problem with the cam seals as it turns out that there are actually 2 sizes available and ktec didnt know that (they supplied the seal kit) i suppose thats acceptable for a clio specialist
quick trip to reno and that was rectified.
with the head built up gave the block a quick clean and a brush of paint - not 100% pleased with the result but i dont care anymore!
then the engine was built up and timed
at the same time i started abusing the chassis with black hammerite - cue getting high in the garage at 1am off the fumes.
Then it was time to pull the retired F7P out
the bay was freshened up with some black hammerite - lost those pics though.
i then replaced the master cylinder (made sense to)
also replaced the front brake lines.
front calipers refurbed and re-sealed
hubs refurbed and treated to new bearings
plastics painted
Subframe refurbished - pics only show it with primer on it but it was treated to hammerite and then a stonechip protection
subframe was then installed along with wishbones and ARB all the bushes were uprated as well as the rear engine mount.
new track rod ends were fitted and new ball joints too.
bought some AVO shocks off AJR gave them a repaint and replaced the 190lb 8" springs with 300lb 10" springs as the 190's were getting coilbound. the 300lbs made all the difference however i will be changing them to 250 as 300 is a little bit too firm around london.
this is how it was looking when it was all fitted up
pic is before i put the new springs on.
also ended up changing the hoses for longer ones as i really wasnt happy with the length on the ones i had.
changed the crappy momo gear leaver for a smaller richbrook one
engine was then dropped back in and plumbed in - ended up buying the full samco set, loom was cleaned and retaped (another boring job) and the broken plugs were all replaced.
at the same time i installed a gunner chip to the willy ECU.
also bought blue ht leads
engine once it was all in
since then i have replaced the header tank for a new one - looks much nicer
no pics of this but i removed the rear beam and painted it, replaced all the rear brake lines (what a t**t of a job) and fitted new brake hoses, load sensing valve, refurbebed calipers and replaced the handbrake cables.
got a ktec decat and fitted after much deliberation
however am finding that the downpipe is very close to the driveshaft boot and the dogbone mount. should there be any additional heatshields in that area?
i have a new scorpion cat back system it will go on while it is at dads work on the ramp - dad will shorten the decat and reweld it and make everything fit nice and tight
thats it for the mechanical side for now - not done much compared to what most people are doing but its a lot for me and the old man!
ok just uploaded some more pics - no order ftl
unseen areas of engine bay blacked with hammerite
gave the gearbox a little clean
wishbones bushed up
how the car was sitting for months lol
getting rid of the surface rust at the rear - bodyshop is cutting out all the rotten parts completly
i realised that hammerite is shite when applied to a surface that has been primed lol
Rear Beam
before
after
Wings & Bonnet on
new wheels
new exhaust (cat back)
headlining out - easy job with a machete - headlining is still in mint condition too!
rear plastics painted
blacked bumper inserts
quick spring swap
crappy general pics
Engine Bay Photo
i have now got a new heatshield from midge - the one on there is a old on covered in kitchen foil lol
criticisms welcome!
trying to have a think of what ive done so far so here is what i can think of
Engine:
New Lifters
Catcam 225s
Catcam Pullies
All Seals replaced
New Dizzy & Rotor
New Thermostat
New Radiator
All new Samco Hoses
New PAS high pressure pipe
New black rubber hoses (where samco ones not available)
New PAS Rubber pipe
Loom Refurbed
New Water pump
new dipstick tupe
New metal ancillary pipes (that bolt on to the block)
New Driver side mount
new Passenger side mount
Rear engine mount fitted with powerbush or whatever its called
carbon canistor removed
Exhaust
New Lambda
new scorpion cat back (stainless)
KTec Decat (stainless)
Williams manifold and D.P
Exterior
HID lights fitted (nicked from fiances car lol)
new yellow fog lights
bumper inserts painted black
door handles colour coded
ph2 mouldings colour coded
PIAA dual tone horns mounted behind foglights (one each)
pH2 grill colourcoded and fitted
headlight strips colourcoded and fitted
willy tailgate to replace rusted one (thanks ClioDan)
new doors to replace rusty ones (thanks dude from gillingham - i forget your name!)
new bonnet (thanks essex biggsy)
new window mouldings
Suspension
Widetrack fitted and powerflex things fitted
avo coilovers with 10" 300lb springs
avo rear dampers fitted
prorace 1.2 15"
stud conversion
all new wheel bearings
front and rear subframe refurbished and all bolts and retainers replaced
Brakes
Braided hoses all round
all brake lines replaced (had to be done after engine was in - doh!
new brake load level valve
all new brembo hc discs
all new pads
all calipers resealed
calipers stripped of yellow paint and repainted black
new master cylinder
interior
clifford G5 with intellistart
cant think of anything else right now lol
It's coming along nicely, nice write up too.
One thing I will say though (I had a valver years ago) I had Avon zv's on it & tbh I found them awful.
really? they were on some wheels that i bought a while ago and as i had them spare i whacked them on. what tyres are people favouring these days? ill probably change them soon.
Very smart mate, what else is to be done ?
well at the moment its at dads work (Jack Barclay) and the arches and sills are being cut out and replaced as they are rotten.
when it comes back ill have to look for a new interior as the one in there is really bad and thats it really. im not sure if i should get buckets as im not sure what they would be like comfort wise day to day
im actually off to malaysia tomorrow for my wedding so i wont have much time (i dont think) to work on it when it comes back from the bodyshop!
thanks for all the kind comments :) alot of hard work has gone into it thats for sure - plan is to get it up to a mint standard run it for a while then ill look into itbs on the current setup.
loving it! would love to do something like this to mine but dont have the balls to rip out the engine to service it cambelt etc lol
well its still at dads work in the body shop having a light tidy up- been slow progress for many reasons but its costing me less than it should so i havent been too bothered - on another note i'm now married - yay me! been to dads work a couple times to do some work on the car while we can use the ramp Installed Scorpion Exhaust cat back system and supersprint manifold setup which i had faced before installing. much better clearance from the downpipe to the driveshaft which was the main reason i got it. the new system is nice and quiet on idle, engine is still fresh so no hard revving. compared to the old one its a big difference the old one mainly because it was blowing in 2 or 3 different places!
fitted
if anyone wants a williams downpipe and manifold let me know. here is the car in the panel beaters bay
some of the discovered rust
if i decide to keep the car ill have it all done a bit more properly but for now it will do new arches
general prep pics
looking a bit nicer :)
compared to when i first got it
its not that shiney lol its covered in dust! thinking about f4r at the moment - seems to be well covered now...
been thinking about what to do with the interior - no its not going to be stripped out!
i need to replace the seats as the old ones are quite rotten - im thinking about buckets but are they gonna be really uncomfortable for daily use? also will i have to do alot of fabrication to get them fitted or is it just a matter of getting the right mounts?
cheers
All you need is the correct mounts and they should bolt straight in. As for comfort, I've never been keen on the ones I've been in myself but they do hold you in place! lol
