1985michael182
So the on going argument of moting a modified vehicle to be used on track.
Rules now state that a "boy racer" modified car to be used on track days must comply with all normal car mot rules.
If airbags, pre tentioners, collision sensors are fitted from factory they must be present and in correct working order. Same with standard seat belts.
Only a rally car which must use the public high way between stages is exempt from these normal rules and a tester can challenge the customer to prove that it is a competitive vehicle.
So... basically there is no such thing as a road legal track car anymore unless you fit all the standard safety equipment back to the vehicle for the mot test and if your on a public high way have it fitted then remove it again at the track.
Found this out on Tuesday when I tried to get my car mot'd at work by the techies (I'm in the bodyshop) at bmw where I work and they failed me for......
No standard safety equipment fitted
Sunstrip encroaching into zone A
3rd brake light not working
No Cat fitted
Yes I should have a Cat fitted but the very limited milage to a track and back its More effort than its worth swapping cat for decat.
Secondly I do hill climbs and sprints so the vehicle gets scrutinised by fia safety officials and I'm pretty sure I'd rather have cage and 6point harnesses than a bloody airbag if I was to crash.
I think its a bit of a joke really
Any thoughts???
No Cat fitted
Any thoughts???
