Rolling Road Results (SHOCKIN)
Should of asked me come with ya eddie then we could of compared the two
I know mate i wasnt going have it done i only went up cause there was a rolling road day on and wanted go see what was running and then thought f*ck it ill put it on as it was a good price and then found out that its loseing power and running rich.
LOL!
Few things to think about.
They use a hub dyno dont they? Apparently more accurate than a normaly one, not sure though???
Also i ran mine there, said it wasnt running right and might be rich and could possibly benefit from one of there remaps - Pulling out a convenient before and after from another 172 - DO ONE!
LOL!
Well they didnt offer me any sort of help like a remap or anything they just told me i had problems and needed to go get the maped sorted on it and as you can see from my graphs and other peoples what have been posted here you can oviously see where the problem is
Thought you had it done somewhere else aswell mate and got 177 was it? Thats probably a more accurate figure. You know theres nothing major wrong with it as it pulls slightly on mine
Unless theres summet up with mine too lol
I know mate but at mikeanics his readings dont show the fuel readings and at WGT it showed it was running as rich as a turbo'd car and at mikeanics he did say the power drops off alot after 6500 rpm but i didnt think much about it untill seeing other peoples graphs.
I need get mine on to see if the flat spot I can feel at around 3k-4k is in my head or not lol
I might get it mapped at RS tuning before the ring mate
Need give Fred a visit tho so he can fit me a new cat to manifold gasket and service my yozza backbox ;)
yeah that aint right, but dont go blaming jamsport just yet, id bet money you have a knackered CTS/ thermostat/ possible lambda issue
But i have a rolling road printout before it went jamsport and it didnt drop off like that id say its down to the map.
Took my car to WGT Auto Developments today to have a power run and it only made 161.6 bhp at the flywheel :( they said it was running too rich AFR Perol reading 12.0 what is way too rich and iv not long had my inlets matched and ported and a custom remap at jamsport and they said it made 188 bhp at the flywheel on there rollers :eek: so theres a big diffrents there and my other mods are janspeed cat back plus decat and itg maxogen filter so it shud be in the 180s iam not a happy person at all as you cud imagine.
Punctuation! Jesus Christ!
IT IS POSSIBLE that something on your car has broken after the map by jamsport (unrelated to the map) i do 3 CTS/thermostats every week on average, very common problem - to the untrained eye you wouldnt spot it
Fair enough but the car still feels and drives the same way as it did when i picked it up from jamsport so if CTS?thermostats has gone since my map then wouldnt i have noticed the diffrents in power???
psycological affect i reckon ;)
just dont go blaming jamsport without solid reason, i hate when people do that as you can potentially ruin a company and their reputation, get it checked by an outside specialist if in doubt
I arnt slagging them off in anyway im just saying somthing aint right and when i took my car in to have the inlets and map done they did other work on my car and i was very happy with what they did and i would take my car back there to get work done, im going get it serviced soon so may book it in jamsport so they can check it out too.
Did you add any mods after you got the work done i.e the maxogen? Also, this is when the limiter cuts in if its not warm fully, maybe this could be the case? I remember seeing you at jam sport when you picked it up, was pretty cold then. Was your car up to temp at the place you went to recently? Just a thought.
Just speak to mark, he'll sort it out for you mate.
Hi mate yes iv had the maxogen fitted since maping but i rang jamsport up to see if it would need the map tweaking if i had it fitted and he said it should be fine.
Yh i remember seeing your car there and since iv had it maped it doesnt limit early when its cold anymore :S mark suppose be ringing me monday.
Yeah i was there today when you rang, me and andrea were quite baffled. Best to get it to mark, and get a run, maybe the maxogen has made it rich??! They will be able to compare with you old one then and sort the problem. If yours has been custom mapped then the limit would of probably of been mapped out. Mark and jamie do know there stuff, they did a fantastic job mapping my cams, im sure the problem can be resolved dude :)
Maybe the maxogen has made it run rich your right and yeah mark defo seems to know his stuff i just need it looking at really and whilst its there they could service it for me as i need it doing before i go nurburgring in 5 week.
a maxogen wont make an F4R run rich, lean yes, rich no
I am a bit baffled by that 197 jamsport did with cams that made 220+, TDF with arguably more extreme mods to the same base car "only" managed 205 or so, so either TDF are s**t or jamsports dyno is a bit "generous"
allways used powerstations rollers and quite a few of us belive them to be about right ktech rollers are knackard thats why they are having new ones installed im going to back to ktech in april to have my map adjusted and to see what i it gets on there new rr
PMSL, powerstations figures are a joke, just looking at the ATW figures should make you laugh and walk away. Ktecs rollers read fine IMO (within 1bhp of SRR on loads of cars I've seen 1st hand at both places, including mine), they just have a crappy PC which keeps needing the software reinstalling (i've been there at 1am having to do this) and Dynodynamics technical support may aswell not exist in this country. They're getting a new dyno because the new one is just a far superior piece of equipment.
You on about that White cup tdf did? How were his more extreme? My cams are a lot more wilder than what he was running! I had more Mods than cams. Nothing to be baffled about.
Each to there own I suppose
