RS200 64mm ported TB
  Golf 7.5R & Clio 200
Hi,
I have been looking into things I can do to my 200. Came across a few threads on 197/200.net about people having a lot of success fitting a 64mm ported throttle body kit. However these all seem to be on 197's, any reason no 200's?.
Im no mechanic, and if Im honest am not 100% sure what a throttle body does. Could someone break it down for me? Explain what it does and the benefits?
Also, they say its around £75 - £100 +fitting. Thats why I thought, hmm. If that actually has any gains it's worth asking the above!
Thanks,
Ry
  Lionel Richie
the idea is larger bore = less restriction = more power
in reality, larger bore = more air at a set throttle position = the illusion of more power
in simple terms
standard TB - lets say at 10% throttle open gives you say 5kg/ph or airflow
large bore TB - the same 10% throttle angle gives 5.5kg/ph of airflow
at WOT the engine can't suck in anymore air because you become limited by the engine itself, NOT the throttle body
Gaz_
  Extreme mode
Clio 197 net w**k themselves into a coma over these, and sprint boosters. Load of toss IMO!
  Fiesta ST-2 Finsport
Ry it's basically a flap that's connected to the throttle pedal that opens more as you put your foot down. By enlarging it in theory it can flow more air and thus more power. However like Fred said its a waste of money just to do this alone. (Much like most things people do to normally aspirated engines)
Don't fall for another forum fads ;)
  Rusty Cup
I would say the best thing you could do to a 200 would be to try and reduce its weight by as much as possible. If you could strip 150kg+ it would be a very capable car (as if it isn't already)
Adding power won't be easy or come cheap. Improving its power to weight is certainly possible.
Gaz_
  Extreme mode
They can't handle opinion, or be told they're wrong
Cams remap = + 20hp apparently ;)
  ST
True dat
I find them to be a bunch of yes men "you've ruined a perfectly good 197... It looks ruddy good sir!"
Yes indeed.. I remember when i had my R27 and i'd had the roof decals removed by the dealer before picking it up.. I'd registered the car on their little gay register and advised that i was having the decals removed and you'd have thought i'd pumped someones Mum lol.
Knuckles
ClioSport Admin
lol!
I remember when someone genuinely ruined a 197, they 'slammed it'... it actually looked undrivable.
Sir_Dave made a very accurate comment about messing with the cars rake and set up etc etc, and they almost lynched him lol
some, not all of them seem to be of the opinion that 'ive changed (insert car part) from standard, therefore making the car better' which I've noticed among people who have a slight interest in cars, but aren't enthusiasts.
