RS200T EDC - Brembo Conversion
  Clio 200 EDC LUX
ROFAG selling new 197 and MKIII RS200 Brembo calipers on ebay but you need an adptor to fit on the RS200T
Anyone know where you can buy the adptors?
Do you retain the standard brake disc?
Do you need wheel spacers?
If I do the conversation I'll swap the brake hoses too for braided lines, any views on the best ones?
Is it worth the effort & cost just to look lovely or would just putting some DS2500s in the standard caliper set up be as good.
Going to change the front pads to DS2500 before playing on a track so want to do this conversation first if it's not a massive ball ache.
Ricardos
  LY 200 EDC
Brembo whoring
Ricardos
  LY 200 EDC
I wonder if the Megane 250 calipers would fit on these ?
Meg 250 are a different offset and believe they use bigger discs. It might mean reworking the PMS brackets or designing new to make the different offset work. The Meg boys run 17" wheels on their 250s so it's potentially doable, with a bit of work.
Ricardos
  LY 200 EDC
To make the 4 pots work
R26 calipers (Red to match OE)
PMS 4 pot bracket kit
Brake hoses from PMS sold separately
Brake pads, I'm using OE R26 brake pads
Have to use min 16mm spacers to clear the wheels
I bought Mr Pink pins as they're better than OE pad retaining pins
Motul 600 RBF brake fluid
Use the OE 320mm discs
Its about, give or take a couple of quid £600 for everything mentioned.
I bought the calipers 2nd hand in decent nick,
Bracket kit and brake hoses from PMS.
Brake pads from Renault.
Mr Pink pins from Turborenault
Motul 600 RBF fluid from Kam Racing
Pad retaining brackets 2nd hand freebie
JamesBryan
Yeah 340mm discs on the MK3 Megane.
