RSI owners, power cable
Car  don't
ok i pick up my rsi 2mora and so need 2 change all me sound system over again
in previous cars have just ran power cable from battery down the inside of passenger wing and through 2 the door and then hidden it under the plastic in2 the boot.
whats best way 2 get the wire done 4 the rsi, is there any holes from the engine bay 2 passenger footwell or anythin like that as its not 2 professional going through the wing and cable gets bit squashed each time the door gets shut.
any advice would b lovely
cheers
.Dave.
drill hole mate, go from the engine side and drill through the tougher material and then just put the drill bit to push through the soft plastic on the interior side. its pretty simple mate but q fidely holding a drill in tha bay, do that carefully then just put wires under the plastic door cover things. somewhere on here i think sugested using vaseline or summet inside the drilled hole, to help keep everything a bit more watertight, but mine seems to be fine> mind u i aint had any rain to test it out yet.
easy ryan
cheers 4 that, in the end i got very frustrated lol, started trying 2 get it through near the washer bottle, then tried going through the wing, didnt look tidy though
then spotted lots of wires going through bit lower behind the battery, cut in2 the grommet and stuffed the cable through and sure enough comes out in passenger footwell quite high up
so thats sorted, what about RCAs though, how can i run them down the car???
cos think their 2 big 2 fit under the skirting??
cheers
.Dave
yeh theyl fit under the plastic inder door skirts easy, run them from the hu over the top of the wires coming out the fuse box( under the glove compartment), then u will wanna fix the wire in some way to stop it falling down maybie zip tie to other wires or summet.
