sheared brake bleed nipple
hi all,
bleeding the brakes on my mk2 clio 172 full fat yesterday.
sheared the rear right brake bleed nipple :dapprove:
From what i've found on the search function renault want an arm and a leg for these so i'm looking to get some from another supplier.
can anyone tell me what size thread these would use.
i had to use an 8mm spanner to loosen & tighten them.
also whats the best way to remove the bit that has sheared off into the caliper?
cheers
Tom
  Tangoed Works
same thing happened on my old mans renault 5 gtt. good to see some things dont change ;-(
  VaVa
I was just thinking that a new caliper might be easier.
In fact f**k it you might as well get some braided hoses and four pots while you're at it. lol.
  renault clio 172
J
Jim NM
I have tried these and failed, they break. Takes too long messing about trying to get the broken bit of nipple out
I bought two calipers for my R5gtt
Try contacting the following who will quote for parts (Breakers)
http://www.1stchoice.co.uk/Default.aspx
Good luck!
