Shock absorber bolt question
Car  Mégane RS
Recieved my shock absorbers 2day, just the fronts, the bloke who i brought them off said they needed 2 new bolts :S and that they were a few quid!!!
anyone know what he's on about lol
The lower bolts which hold the shock to the hub he's on about ideally you should replace them but I just use locking compund and torque them up right and there fine.
Cheers Edde, where can i get them from lol??
Renault for offical ones.
You can in theory run any bolts 14mm diamter thery are but if you want to run more camber then use a 14mm for the bottom and a 13 or 12 for the top one.
Just use some decient bolts. B and Q arn't acceptable. They arn't done upto much torque (100NM) but if they fail then its a big crash time.
ok lol, i wont be fitting them hopefully fred will lol, any idea how much they are from Renault and the part numbers? cheers Vinny
Yeah... if there is one place you get the right bolts, it would be the lower shock bolts. Could be nasty !!
yeah might need 4 of them too lol, mine are rusted, how much for them too lol, shall be going into renault to purchase bolts lol
A few quid. Say £6 for 4.
Fred will have some spare though most likly.
Just thinking if you don't have an RS (I'd though you had a 172) there 13mm bolts. not 14mm like the 172/182 use.
cool ok, well i will go into renault and see how much they are, stupid question but are the shock absorber bolts universal cause i have a set of spax dampers, thanks
