Track 172cup
Just a quick one thats got me a bit puzzled.....
Should you be able to fully extend and compress a shock/damper and it stay in that position or should it rebound to a 'set' position ? I know the shock is there to dampen the resonance/bounce caused by the spring but for some reason i had in my head that it should still return to a set position when not under load (off the car)
Bought a set of KW coilovers and in this case it's the rears i'm talking about (basically Koni adjustables)
oh and if anyone has the installation instructions they could send over then it would be much appreciated as i need to find out if the 2 large metal washers/collars and the black plastic bit above the bump stop in the pic below are needed as they didn't come with them
