Should I replace this crank pully?
  Sell me your 197
When my timing belt went, it wrapped itself around the crank pully 3 times. When it came to removing the crank pully to replace the belt, the pully was stuck on.
I've used a pry bar to get the pully off, but accidentally damaged it:
Will this be fine to reuse? Unfortunately replacing it is a hassle, easiest way would be probably to get one of you guys to send me one from the UK!
BTW just for fun, here is a pic of my timing belt:
  Astra GSI, 172, Golf
break of the damaged bits. then file away any bits that may interfere with the aux belt.. then re-fit
  DON'T SEND ME PM'S!!
I'd fit a good used one personally. How the hell did you damage it? they fall off once the bolt is loosened
  Clio MK2 1.4 16v
aren't these supposed to be ballanced?
Hence, if i chunk is missing, it would need rebalancing in order to use the same?
  Sell me your 197
It didn't fall off when the belt was loosened... Took quite a bit of force to get it off.
  Ph1
Why didnt you just use a knife to cut it off? :S
Better off getting a new or used one for peace of mind
