Sir_Dave - Project Track Shed
What parts have gone and what's still in it?
Gone:
Bilstein B8's/Faulkner springs
Cage, buckets, mounts, harnesses, steering wheel, stereo
Exhaust, manifold, induction
Gti6 brakes, pads, 23mm master cylinder
Wheels, tyres, locking nuts
Stayed:
Shell, engine, box, brakes
I basically stripped off anything that was worth anything ;)
My mate Sam bought your wheels.
I sprayed them for him Monday. Fitted Today.
The track shed now has a new home :)
Just done a deal with Budgie on my sick 172 Mk1
Plans are
PE2 tyres all round
306 gti-6 brakes
cat back exhaust
4-2-1 manifold
air filter
This image has been resized. Click this bar to view the full image. The original image is sized 1024 x 768 and is 676 KB.
Awesome!!
Look forwarding to seeing another project thread then lol ... have a good read through here if you havent already, gives you some hints as to the best/best value bits to buy for it :star:
Get everything 2nd hand, off 106owners, 106 Rallye Register & Sax-P!!
just read through this start to finish
i want a saxo lol ;) awesome stuff
Just having a look on P/H and found the old girl was for sale again :(
mk2 Black VTS (2001)
94,000 miles£350
Up for sale is my Black mk2 saxo VTS,
The following has been done to the car.
Front lowered 50-60mm with unknown spring and b8 dampers,
rear lowered to suit allso using b8 dampers,
group n gear linkage.
Quick shift, The little extension that goes on main rod arm..
it has very recently had a new alternatert pulley, tensioner and belt fitted less the 500 miles ago.
new 90% brighter bulbs.
Car now has no tax and mot!! Of the road!!
new nearside driveshaft 700 miles ago..
Also inclueded is a set of 50mm spedline springs because i wanted to bring the front up about 10mm
and new powerflex center engine mount.
bad points..
body work has a few dents. one front offside arch and one the boot.
two of the rear seat belts need replacing as they wont pull out.
gear box seals have gone so gearbox has no oil in it at present but wont take much to replace the seals and oil and it be fine, box still feels fine..... . and off side driveshaft inner boot needs replacing hence price..
This is a lovely little car that just needs a little tlc to get it up to perfect working order.
this is what i was planing to do but due to work and lack of time iv not been able to.
