Slight hesitation and sluggishness 172
  120d M Sport
Hi,
My 172,which has always felt very responsive and lively has got a bit sluggish seemingly in the last week or so.
I also notice it's a bit surgy or hesitant in the lower revs from cold, not that I ever take it past around 3.5k before it's warmed up anyway.
It's doing no better than about 36 mpg on my daily commute which is 32miles, mostly dual carriageway where I sit at 70.
It's had a new lambda sensor in the past according to invoices so I'd hope it's not that, would new spark plugs be a decent shout?
Cheers,
Al.
  120d M Sport
Ahh, do these have two? I wouldn't know which one mate just know its had one in the past from an old invoice.
It doesn't misfire as such just hesitates a little through the rev range, it goes away once warmed up but then seems a little sluggish, like the handbrakes partially on!!
Other thought is tdc sensor which did play up a few months back (car wouldn't start) which has been fine since I took out and cleaned, could this need changing?
Cookson
  Mk1 Audi TT 3.2 V6
They all hesitate when cold.
I would chuck a set of plugs in, see how it feels then. When was it last serviced/oil changed? That can make a difference.
PS - Make sure you get the correct NGK plugs and use 5w 40 oil
  120d M Sport
Last changed the oil less than 1500 miles ago using Fuchs 5w40 stuff from Opie. Always run it on super unleaded too.
Think you're right about the plugs though, I don't know when it would have last had some (if any) though it is on 112k.
Interesting to hear that they all hesitate from cold. I must say I hadn't noticed it before though.
Thanks btw!
  04BGFF182CLIORS
Mine also seems to be suffering slightly, even when warm. I put it down to the fact its quite a cammy engine, but maybe it does need plugs/lamda?
It feels slightly flat/hesitant at cruising/traffic speeds (40/45mph) but is fine when you push it a little.
Did you find a solution to this Alex?
  clio 172 phs 1
Agreed that they all are a bit hesistant when cold.....mine is too and always has been......
