right 1st off, a bandpass enclosure will not exactly be a small box, for argument sake, it will be the size of a sealed and a ported box mounted together
taken from the tech info supplied to me when i started my installation training with Lightening Audio
Bandpass Enclosure
Pros
Acoustic gain can be built in. This means one speaker can be as loud as two or more (using the same power input) over a limited part of the spectrum.
Specific low frequency performance can be designed, inclusing lower cut-offs than would normally be possible with simpler boxes.
Cone excursion can be altered by design, reducing distortion and improving power handling.
Cons
Box construction is considerable more complex.
The more acoustic gain you design into th enclosure, the more boomy they tend to sound.
Boxes designed for extended low frequency performance will have less SPL output than a vented or selaed enclosure.
if you need any more advice regarding bandpass enclosures, by all means just ask, i will be hapy to help
its my box of choice by the way
