space saver wheel- HELP PLEASE
  2015 ST2(MO)/CorsaLE
if a car has 17 inch wheels on it can you use a 14 inch or even 13 inch to get you home, or would it be a no no
thanks
thanks ^^^ its for a corsad, has 17s on it, our old corsa came with a spare, and was going to pinch it lol before taking it, but not actually sure it will be any use. think i need more a 16 inch from a scrap yard, the space saver im on about has a massive fat tyre on it
will it be of use ????
think ill keep it and try, guess as long as its not hitting anything should be ok ?
its a 13 just checked with a massive tyre, old corsa running on 14s
as you say could fit on the back with drums and swap them around if needed to if a front failed put the back in the front - ie keep the little one at the back to get you home ???
