Sparco seatframe.......
bozothenutter
Mounted my raceseat today.....:mad:
Do not use a clio specific sparco frame.....it makes the seat as high as the standard seat!
Anybody know of a good alternative?
Yep, other than custom, OMP seems to be lower. I have OMP in mine, I'm 6ft 4 and I have no problems with the seating position :)
Where are the harnesses mounted, look a bit suspect to me from the photo.
Will look for OMP then.
Harnesses are mounted to the top seatbelt mount ar the rear and to schroth thingies at the sides.(one on the front seatbelt mount, one on the bolt that mounts the seat to the floor)
Bad idea?
anybody else know/think what I did wrong?
the shoulder belts run slightly up, but within Schroth tolerances (20deg)
the lap belts are mounted to the oem belt mounting point with Scroth clip on eyes
the crotch belt is mounted to the floor with the plates that come with the package.
I've put a Sparco subframe on the seat in my 172
I hadn't really sat in it enough to notice how high it was until we got the car moving again, feels way too high
My 182 has Cobra extra low subframes and the seating position feels great, i might have to look into changing to OMP ones if they're alot lower.
