spedo problemo
last nite on the motorway, i looked down at my speedo at it claimed i was doing 0mph but to my excitement, the miles on the clock also stoped :). then it came back on-it did this twice, has anyone else had this and what did you do?
  Clio II 1.4 Priveleg
Its an electronic speedo driven by a transducer where the original cable type would PLUG into the gearbox. Check the connections to the transducer to make sure they are in good condition. Sometimes just by unplugging/plugging in the connector will cure this problem.
Hope that helps.
Bob RTE
  Revels Mum & Sister
Mine went on My Valver done the same as yours. Did start messing with the IDling though.
But no Miles on the Clock hehe
  Williams 2, STi N12
The ones on the valver and willy are spindles in the gearbox and are a sealed unit, the only way to replace this is to over haul your box. The idling messes up because it also has a sensor in there so when you go over a certain speed or revs it will stay at about 1200-1300 rpm.
